Discussion Starter · #2 ·
I've had my truck in before and they blamed my vibration on tires. I didn't push the issue, but new that the tires were perfectly balanced and the truck did the same thing when I use my 35" tires. I think I might order the parts and try fixing it myself. Have had a vibration from 30-40mph since day 1.
i had this problem to. the bulliten is about puting in shims between the rearend and the leaf spring. install a .5 degree shim in from the front and re test. if it is still present install a 1. degree shim in its place. smae process if still present with a 1.5 shim.
stevie ray nissan tech
