Hi everyone. I'm just now getting around to doing this. My little brother was driving the truck one day and he said that the engine stalled and won't crank afterwards. I hooked up the obd2 scanner to the truck and got the code p0430. I searched the forums and it was related to 02 sensor and Cat error code. I'm not sure if i'm doing it right but i'm going to embed a video of how i did it.
I've also read that there is a screen somewhere that somehow can be sucked into the engine that would cause for me to replace the motor. How can i diagnose that problem to eliminate the thought of having to replace the motor?
When i try to crank the motor, it'll crank fine with no check engine light of any source. I then shut down the engine and test it again. It won't crank. The only way i can crank it again is to let it sit for a while. maybe a few days.
