1 - 3 of 3 Posts
My battery finally went on my 06 w/ BT. The Odyssey website battery selector recommends the PC1500T rather than the PC1700MJT, which is fine w/ me b/c its much cheaper and I don't have any accessories drawing a lot of power.
Has anyone tried the PC1500T and how does it fit compared to the BT battery?
An alternative, is the PC1700. It lacks the Metal Jacket of the PC1700MJT (MJT=Metal Jacket) but is exact same battery inside. It can be had for about $300-310. I would not go down to the PC1500T. The savings isn't worth it. Too important of an item and you are trying to go with the best you can.
Another alternative is to go to Sears and get a Platinum which cost $190. It is made by same company as Odyssey and has same specs. You may have to order it to get the version with the right hand positive post we need. The wrong version is a stock item.
If you go with the beefy odyssey battery, make sure you strengthen your battery holding device to hold that sucker down! I doubt the stock clip could hold that beast down if you do any offroading.
1 - 3 of 3 Posts
