1 - 20 of 41 Posts
So...I recently purchased a 2018 Titan SV 2wd. The truck is optioned almost perfect with the exception of a brake controller. I want to install one...from Nissan. The truck has the 7pin on the bumper and the harness under the dash to connect an aftermarket brake controller along with a generic harness to wire one in. My question is...has anyone put an OEM brake controller in a truck equipped like this? I know it’s a lot more expensive but seems ideal with the pocket in the dash and the wires already “in place”. It seems like the correct wiring harness would make it almost plug and play.
If anyone has had any success I’d definitely like to hear about it.
https://www.titantalk.com/forums/2016-titan-general-forum/411242-7-4-trailer-harness-question.html
Maybe he can shed some light?
I've been searching don't see anything yet about installing OEM brake controller?
Good Luck
Thanks. I think my approach is going to be finding a salvage truck to create a harness from. The plug into the oem controller and 5” the wires is all I should need. If anyone comes across one please let me know.
You might have more luck posting 2nd Gen Titan stuff in the 2nd Gen Titan forums.
I was wondering when did 1st Gen Titans get an OEM brake controller, I wish! Hate banging my knee on my Tekonsha
I looked into this yesterday while looking at the accessory catalog. The accessory trailer brake controller comes with a harness now. Can’t rememeber the price or part number though.
Did anyone get anywhere with this? I would like to put the factory Trailer Brake controller in my truck too. My Truck appears to have all the needed relays under the hood.
I installed the factory brake controller in my 2018 titan-bought the controller from dealer and the only hard part was getting into dash. Once I figured that out the harness was there-plug and play, works great!
I installed the factory brake controller in my 2018 Nissan Titan, it is plug and play, harness is there ready to go!
The hardest part is getting to it-had to remove part of console and dash.
Great to hear it is very easy for you. We will be working on uncle's new 2018 Titan soon right after we finished installing the bumpers and replacement jeep tops on his current Wrangler project. He will getting a brake controller as well from the dealer.
What is the part number, I looked this up last year and was told that if your truck didn't come with the OEM brake controller then the harness that plugs into it isn't there
You are getting incorrect information- harness is there. As to the part number not sure, dealership located it by searching for “TBCU”, trailer brake control unit.
When you bought it from the dealership did it come with any wiring or harness or just the unit itself. Thanks for the help. I have wanted to do this since I bought the truck a year ago.
So for those of you who don’t know this all Titans are wired with the same wiring harness. Wether it is an S model or the platinum editions the only difference is the options. I work at the Nissan plant in Canton Ms so I have done several changes to my based model Titan. This factory brake controller is my next project I will be hitting up the closest junkyard to see if I can acquire one. Good luck to all if I get a part number I will post it.
There is a guy on titanxd forum who said that he took his dash apart and couldn't find the harness. That's why I was curious. I would love to add this and have been using an aftermarket one since I bought the truck
I had an Armada older edition and it came without fog lights, well when I crawled up under the front I noticed it was already wired for the fogs just had to buy switch and the fog light assembly. So I am pretty sure 1st gen titans are wired the same as well not sure the part number for the older titans.
1 - 20 of 41 Posts
