1 - 8 of 8 Posts
I dont have tow package and im palnning on adding the class III is that the right hitch? also i think my truck is pre wired ( 2006 cc se) so i would have to buy the wiring harness ? thanks
Your truck should be per wired. Go and get the OEM hitch it comes with everything you need. The per wired plug on your truck connects to the the OEM hitch. Easy bolt on to frame and plug in relays under the hood. I bought one for my 08 installed in about 30 minutes.
I got mine from the dealer, Since I am in the DFW area, and Courtesy is also in this area, I went to my local dealer closest to my house and asked them to match the price, They did. took about 20 minutes by myself to install it, the use of jack stands helped.
I used my 13 year old son as jack stand.
You knew you had him for a reason, didn't you?!?!:jester:
Discussion Starter · #8 ·
mayb ill try that on my dealer, i doubt it will work on them tho
1 - 8 of 8 Posts
