1 - 6 of 6 Posts
I have searched and searched and i can't seem to find the correct part number for the OEM XE Stereo Bezel for an 08 model. I am wanting to put a double din radio in and remove my factory six disk model, but courtesy has a ton of part numbers and no pics. For anyone that has done this, can you point me in the right direction? Will I need a trim ring as well? Thanks!
I just went through all this for my 2004 Titan. I just googled "2004 Titan xe radio bezel" and managed to find a photo of the back of the panel and zoomed in on the manufacturers part #. For my truck it was #68260-7s001. I called the dealer, gave this # to them and it was the correct one. The dealer also gave me a list with a bunch of #'s like they did to you, I just went down and highlighted all the part #'s the description said "xe" in the text. I then only had a couple to choose from and after finding the photo online just matched up the part # to confirm it was the correct part I needed. Good luck.
Crutchfield sells them aftermarket as well, double din and they match perfectly. They actually give it away for free if you buy your audio unit from them.
Is the cover you need going to look like this one??
yes but that looks like the metra kit. i saw a 2010 SE titan that had a stock one of those and was hoping to get the better quality stock one. I have the metra one and it actually isn't that bad, i was just scared after reading things about it on here.
if you keep an eye on ebay they pop up there from time to time. I got one for my 04 XE for like $25. Just make sure the seller gives you some good pics because those small scratches are hard to see in photos.
1 - 6 of 6 Posts
