you could always call a dealership, give them the part number and find out what comes with it.
I already know what comes with it, it's listed in the link. I just need to know if the brackets are necessary.you could always call a dealership, give them the part number and find out what comes with it.
Yep I have tow hooks. I thought it mounts with the tow hook bolts to secure the front of the plate, and the brackets secure the rear of the plate?You will definitely need the brackets. Do you have tow hooks by any chance? My tow hooks and skid plate are both attached with the same brackets. If you have tow hooks, you might already have the brackets
Maybe I should just buy the plate, fit it and see what other pieces I need.Tow hooks and brackets are separate... Need tow hooks or stacked washers to install OEM brackets... However, you can just fab up a custom bracket as well... The only thing you need to do is make sure the front of the skid plate clears the bottom of the bumper...
lol.Yeah the back bolts are 10mm and you should already have the holes for those. Honda if you want to take pics, go ahead. The earliest ill be able to pull it off will be monday. I'm about 400 miles from home and on my blackberry![]()
