1 - 6 of 6 Posts
Is it leaking at the gasket?
You can use the fram oil filter gasket to replace a leaking oil cooler gasket. I did this to mine and I'm leak free now.
Just figured I'd suggest if that's why you're looking for a new oil cooler.
You can also purchase just the oem gasket for pretty cheap from one of our supporting vendors. I can't recall which one off the top of my head, but use the search function and you can likely find the right source. Seems like the gasket is pretty cheap, too.
1 - 6 of 6 Posts
