Spray the areas with Brakleen or Degreaser, wipe off, and run engine for 15 minutes. Or something like that. use flashlight and it will usually show up. I keep engines at work sprayed clean quite often, just to see such leaks. Engines don't have to be coated in thick oil/dirt gunk.
You'll find it!
