Hey guys thought I should let everyone know my troubles so that you can help prevent them from happening to you. So after 3 weeks of my 06 with less than 24k leaking all over the driveway this is what the dealership has replaced/done (sorry if it sounds weird I know nothing about parts but this is what it says on the papers):
-1st time: Re-torqued the transfer case bolt back in
-2nd time (2days later): Found that the transfer case bolt and seal was not there!!! So they replaced the bolt/seal!
-3rd time (And still in the shop): Driveshaft seal leaking which means they are going to replace the entire driveshaft as they have seen this happening on Titans where the driveshaft is tearing up the seal.
I just wanted to make a list of problems I've been having this month so that everybody can have a heads up and hopefully prevent it. Luckily its def under warranty so the dealership is paying for ALL of this so far
