I have a 2004 Titan SE with just over 75000 miles on it. It has developed a leak around the oil pan. Nissan seems to use RVT for these gaskets. I have found a few places that sell a oil pan gasket for this truck. Anyone use one of these or do you think I should just use the RVT again?
Technically, RTV sealant was a factory money saving scheme. Less gaskets to make and stock.
Technically, you can use either with similar results. The problem with the RTV is that if both mating surfaces aren't perfectly clean and free of contaminants and oil, it will leak. A gasket will pretty much seal once Titan'd. Please note that even though some gaskets were used in various places, there are times when RTV is used in conjunction with gaskets, like at the corners or in difficult to seal areas. I doubt that you will run into this with the oilpan, but check the gasket for voids or open areas that may need RTV. Sometimes a bit of RTV is also used to hold a gasket in place so it won't move while installing the parts.
Basically, you can go either way. The gasket is a more dependable method, at least on a replacement due to the possibility of oil residue remaining on the parts.
Had an engine oil leak on my 17 Titan SV that turned out to be the oil pan gasket, and yes they are silicone and i would like to know why. Dealership said is was a common issue... Worse part is that they put the old oil (7,000 miles on the oil) back into the truck because warranty will not cover the oil change. Anybody else experience this?
That is low. You should call Nissan and complain about the dealership reusing the drained oil. If this was recent, I would change it out quick. Their containers are typically filthy. Also, find another dealership.....
