1 - 1 of 1 Posts
My 2006 Titan XE 4x4 always reads high oil pressure. A have noticed that at times it will fall but will then jump right back to high pressure. I believe the cause is a bad or stuck oil pressure sending / regulator unit. I have look online and at my manual for the truck but am having a hard time finding the part on the diagram and the part number. Any help would be much appreciated.
I also have been getting a lot of bank one and bank two down stream (and a few upstream) O2 sensor codes. According to the reader it says something about them not reading right and not reaching temperature. This has mostly occurred when its been cold outside or the truck has been sitting. Wondering if anyone else has had this issue and if its best to replace them or wait and see if it does it again in warmer weather to rule out the outside temperature on the day I get the codes.
1 - 1 of 1 Posts
