1 - 20 of 20 Posts
I saw a thread on here last week about changing out the oil pressure sending unit. Does anyone know if this is something that can be done DIY or does it have to be done in a shop? I am about to change my oil and wanted to knock this out as well. Is there a diagram on how to do it? Thanks!
why would you change the sending unit?
here, this is from my service manual on the oil pressure unit
idle pressure is 14psi and 2k is 43psi
Reactions: CapNemo
Discussion Starter #4
My oil pressure sending unit went out about a year ago. My gauge has been pegged out ever since.
So do I just need to replace the switch?
yep, but you should at least check the pressure
Discussion Starter #7
Can you get the switch at an auto parts store or do you have to get it from the dealership?
Discussion Starter #8
Well, I ordered a new Oil Pressure Switch yesterday from Autozone and got it in today. I got up under the truck today to change it out as well as change my oil. The switch was a little bit of a pain to get to, but once I figured it out it wasn't bad at all. I went ahead and bought a 24MM deep socket when I picked up my switch and this helped me save a lot of time and heartache. After I got everything changed and installed I cranked her up and walaaaa! My oil pressure gauge works again!! Whooo hoooooo! LOL! In the past two months I've learned how to change out oxygen sensors, change break pads and rotors and now I learned how to change out the oil pressure switch. It's amazing how much you can learn and actually do yourself if you take the initiative to tackle it. I've saved myself over $500 in the past two months by doing the work myself :) Thanks so much to all of you who gave me pointers and advice through all of this :)
that good to here!!!! I hope the pics helped out
Discussion Starter #10
Sure did!! :)
I am once again impressed with the technical info supplied by the patrons of this site. One more item stored in my memory bank, just in case.
Just had the same problem. Looked on TT and headed to Autozone. Had the part in stock $70.00, got the job done in 15 minutes after taking off the skid. Titantalk is awesome. Thanks guys
My oil pressure swings low when at idle but picks right up when the rpm's pick up. Is that indicative to a bad sending unit ? 2004 Thanks
Could be, but it may also be indicative of an engine that has lots of miles on it.
Thanks.. The truck has 145.000 miles on it . Original owner
My 05' did the same thing with only 55k miles on it. Never could figure out why either. I use to put in in neutral at long red lights because I started to get paranoid about it dropping for a long time. Now my 2010 w/ 80k miles holds right in the middle no matter what (stopping or accelerating).
Trying to figure out if its the oil pressure gauge switch or light switch ? Through napa the gauge switch is about 60 and the light switch is 15...
1 - 20 of 20 Posts
