21 - 26 of 26 Posts
'07 gauge goes to the middle and sticks there.
Thanks for the quick reply guys! So it should just hang out straight down all the time? off, at start up, driving and anything in between? It seems like it should have some movement but maybe not.
It's like mine has two settings: on and off.
I have an 08 and broke mine doing some fabrication work under my truck. Does anyone happen to know the part number or where I could find it without calling the dealer?
So I'm new here and was just doing some searching about my oil pressure gauge. I've had the truck for about 3-4 months. When I first got it(2004 SE I believe) It seemed to move around based on throttle. Right now it goes up to just over the middle and really stays there even under higher throttle. I had the oil changed and it still seems the same but this morning when it was cold it moved up a little but after warming up stayed just above middle again. when at idle it drops down to just above quarter pressure. Any thoughts? Maybe the pressure sending unit?
On earlier models the gauge moved around. Newer models (like my 2007) the gauge doesn't move much after initial startup.
One of the early model guys will have to chime in to tell you if the gauge at the quarter mark is OK or not.
21 - 26 of 26 Posts
