07 4x4 cc xe. I did the intake mod with a k&n filter. I am currently running with the secondary cats removed a custom x pipe and 40 series true dual. My question is do i need to reset my comp (i.e unhook my battery) or should it be ok without running to lean??
I never reset mine. From what I've heard your ECU will need a little bit of time to learn and get used to the mods.
some say its good to start from a clear memory so it will learn the new parts installed compared to your driving style.
i cleared my computer, i cannot say it did anything.
i would do it to start from a clear memory so it learns your driving habits from the new installs.
i do know that resetting memory of a computer can help.
when i was working on hyundai's we used to clear memory due to a transmission shifting issue.
It will learn faster if you don't re-set it. Just go out & do a couple 0-60 WOT run's back to back to speed up the learning process.
