1 - 3 of 3 Posts
Hi all. I have an early '08 Titan with the 2.94 gears. My pinion seal is leaking badly, so I need to get that fixed. I am also contemplating a gear change. At least to the 3.36 ratio. Maybe more. I spoke to Hooper's rear end shop yesterday, and the gentleman said if I change ratios, I will get a check engine light, and will need to figure out how to address that as well. Is this correct? A C/E light after a gear change? For those of you who have done a gear swap, how did you resolve this issue? Also, looking for opinions on what ratio I should go with? I don't tow more than 4000 lbs, but I am running a leveling kit with 305/65/18 tires, and will soon go to 295/70/18's (slightly taller, but waaaaay cheaper than the 305's). The truck does alot of highway driving, so would you leave the 2.94's in it?
Another point, the guy at Hooper's recommended I leave the gears as-is, and just get a programmer to help wake the truck up. Not sure about that one, as I am in CA and need to pass smog.......opinions welcome!
I know there will be some difficulty with the gear swap, but at least it's a 2wd.
Make sure your axle vent is working when you change that seal.
Reactions: cnj
Thanks. I will. Ordered the Toyota fitting for the axle today. I'll make sure I do the mod before having the seal replaced.
1 - 3 of 3 Posts
