I’m considering purchasing the SST Lift kit from readylift (2” in the front and 1” in the rear) for my 2018 Titan SV. I’m just wondering if anyone has done a similar lift to their Titan and has any recommendations? Like maybe also upgrading the shocks at the same time or if maybe they have been able to fit bigger tires without rubbing? I’ll most likely stick with the same size of stock tire but I had a friend recommend new shocks when I get the chance. Any advice is much appreciated.
The main thing I have heard is that anything over 1.5" on the front will likely cause some amount of coil bucket contact. May be worth going with a 1.5 instead of a 2, its what I had on my '17 SV and plan to do on my '18 pro4x
Reactions: Malo94
So you had the 1.5” kit from ready lift on your SV and had no problems?
Not sure of the exact brand it was, I got it used. But it was 1.5" and had zero issues whatsoever
