My Trans Am has TCS witch does basically the same thing.Batman229 said:Anybody here know of any other cars or trucks with Active Brake Limited slip or is this the first of its kind?
Our '03 4Runner has it as well. Toyota calls it Traction Control.Batman229 said:Anybody here know of any other cars or trucks with Active Brake Limited slip or is this the first of its kind?
The Lexus version of the 4Runner has it also.karlconnell said:Our '03 4Runner has it as well. Toyota calls it Traction Control.
Karl
Well if you want to get technical, on the 4Runner VSC (Vehicle Stability Control which has nothing to do with tow packaging) and Traction Control (TRAC) work in concert to apply the brakes to a slipping wheel while diverting power to wheels that do have traction and also reducing engine output. It's the same concept as the Titans VDC and ABLS, both act electronically or as a virtual LSD.Batman229 said:traction control is more then making sure the wheels propel the car, it also keeps the car straight when it begins to skid using brakes and throttle, traction control is the vcd or vsd with the tow package. The abls is a totally different animal. It acts as a limited slip but electronically and not mechanically. What other cars use abls?
I think it works great. We went to New Mexico a few weeks ago and got caught in a bad snow storm and the VDC worked flawlessly as well as the ABLS when turning corners.CI338 said:Don't the Touareg and Cayenne have this type of system available? I'm less than happy with it, with one tire on ice the truck will barely move even with the system working.
I think it works well also. I have to pull out and merge onto a high speed asphalt road going steep uphill from a gravel road. When one wheel hits the asphalt, the other still on the gravel, I can step on it hard and the SLIP light on the dash goes on and the ABLS kicks in nicely.karlconnell said:I think it works great. We went to New Mexico a few weeks ago and got caught in a bad snow storm and the VDC worked flawlessly as well as the ABLS when turning corners.
If you try to spin the wheels when turning you can feel the ABLS kick in before the VDC reduces the throttle response.
