Owners of lifted Pro4X models... what suspension setup are you running?
1045 7
I'm curious to see what suspension setups folks are running on their Pro-4X models and searching the forum has failed to yield many hits on this. If you own a lifted Pro-4X, please check in with a post in this thread and let us know what setup you are using. Ideally if you could list the height from ground to top of the wheel wheel arches (front and rear) that would be great too.
Thanks.
:cheers:
1 - 8 of 8 Posts
Pro Comp Stage II - Deaver C-30s with no block - PRG traction bars
45" Front / 43" Rear
I have some 1 1/2" PRG rear blocks on the way to level it out.
rough country 6" bracket - stock pro4x co's with 6" rc spacer, 5.5" rc rear block
47" up front / 46" rear
i have c-30's and s.a.w. bracket co's collecting dust in my garage so one day they will be on
So no bracket, just an extended travel pkg? Any Pics?
I've also got the SAW CO with SAW extended rears and a block in back... all PRG items, with the traction bars thrown in.
Nope. No bracket. I'm limited due to my parking garage at work or I would have probably gone with a bracket lift along with coilovers, ucas, shocks. Unfortunately my parking garage says it is 6'6" and my truck is 6'7" so I can't really go much higher. Pics in the post below are before the 1" block in the rear but you get the idea.
http://www.titantalk.com/forums/tit...dict-nitto-trail-grappler-prg-ext-travel.html
1 - 8 of 8 Posts
