1 - 14 of 14 Posts
Had been getting recurrent SES light throwing P0455 code. Gas cap looked OK so I went right to replacing the evap control valve. Installed the Dorman replacement yesterday along with the inline fuel filter mod (discussed elsewhere on this forum). Today, SES light back in and now I'm getting P1446.
Any thoughts????
Thanks.
Jim
Any thoughts????
Thanks.
Jim
What's this inline fuel filter mod?
P1446
Possible causes
- EVAP control system pressure sensor and the circuit
- Blocked rubber tube to EVAP canister vent control valve
- EVAP canister vent control valve
- Water separator
- EVAP canister is saturated with water
I would double check the Evap valve.
P1446
Possible causes
- Water separator
This is the fuel filter mod I was talking about. It's on p2 of the sticky for how to replace the evap control valve. I had a ton of crud in my tube leading to the valve so I thought this would be a good preventative measure.
http://www.titantalk.com/forums/attachments/titan-faq-howto-area/106358d1278526520-how-replace-14935-am60b-evap-vent-control-valve-assy-sticky-filter_001.jpg
Think this mod could be the culprit? Others reports good results. If not, what's the next best diagnostic step? I know you said to check the evap valve but in was brand new. Think I could have gotten crud in the new valve?
Thanks again. Big trip coming up in a month and I prefer not to run with the SES light on.
Jim
Ah OK. Get the new and improve OEM vent valve and do away with the filter.
You can take the fuel filter off and see what happened.
Admittedly I totally cheaped out with the fuel filter mod. I just replaced the cats/manifolds so I was trying to make this fix as inexpensively as possible.
I had to cut the hose to get the filter to fit so I won't be able to reconnect it to back to the barb on the frame if I remove the filter. Any harm in running it with a short hose connected just to the value? If not, I'll pull the filter, clear the code, and see if the lights stays off.
Is the OE vent valve significantly better than the Dorman? I thought that concensus was that the Dorman was OK.
Thanks again! Much appreciated.
Jim
Jim
I would check the electrical connector as well to ensure it is properly connected to the evap valve. The new OEM valve is much better than the crappy old design or any of the aftermarket ones I have seen. It has a much better solenoid valve that resists gumming up. New design is part # 14935-JF00B. I installed mine over 3 years ago and never had an issue since.
Discussion Starter #7
Thanks. That new OE valve looks quite a bit different than the original value (and the Dorman replacement). I just removed the filter, rechecked the connections, and cleared the codes. If the SES light persists, next step will be to return the Dorman and go with that OE replacement.
Jim
Discussion Starter #8
One additional question. I removed the fuel filter mod and reattached the longest piece of hose that I had to the evap vent. I ran it up towards the bed so the open end if about 9" above the valve, but because I cut out a section for the mod I didn't have enough hose to reach back to the original barb. Any reason why I can't drive like this for a few days? As I understand it, the barb connect just went into the frame and wasn't filtered anyway so I think that this should be OK.
Jim
I would worry about foreign material exclusion with an open ended hose under the truck. Do you have a male-to-male hose barb which you can use to re-attach the piece of hose you cut off?
Discussion Starter #11
Did you fix this problem?
I removed the fuel filter mod and cleared the codes. So far, the SES light has remained off. I still haven't been able to reconnect the hose back to the barb in the frame so I've been only driving the truck sporadically. But the P1446 came on quickly after originally installing the filter mod so I am hoping that the fact that it has remained off for several days may be a good sign.
Any thoughts????
Thanks.
Jim
I had both p0455 an p1446 when i changes my evap vent valve.. what i did was took off the charcoal evap box and took the hoses off blow some compressed air in there and some dust came off reset the engine light and it hasnt came back on ever since.
I got this same issue. I've replaced the solenoid(though it wasn't the redesigned part), but it still happens. I don't think the part was bad. I'll have to look at the hoses and canister. Has anyone tried any sort of elimination method? For instance, I hook everything up, except leave the solenoid unplugged from the canister. Solenoid still operates as usual, this would just negate the canister. Just wondering if anyone has done anything like that.
Also, when pulling off the connector, it was stuck on from dirt, ect; and the wires pulled out. I pulled the connector apart and re-crimped everything. So, the connector "could" be an issue, but things are working the same as before I replaced the part. Is there a particular order for the wires? I didn't think so as the part is a simple "on/off" operation.
I think I am going to pull the solenoid from the canister this weekend and see what happens. Worth a try I suppose. Might not help, but it's winter here and I don't have a garage big enough for this thing; so I'd like to try and pinpoint where my issue lies instead of lying on cold cement.
1 - 14 of 14 Posts
