Hello fellow members. I have a 2004 Nissan Titan King Cab 2WD with 101K miles that has a leaking rear right axle seal. So, I am planning to replace the seal shortly. I will also take advantage of the teardown to take a look and service the parking brake shoes as well as the rear differential fluid. I have a couple of questions. If I have to adjust/replace the parking brake shoes, it states on the NFSM to not reuse the 10mm adjusting nut if removed. I'm referring to the one that lies close to the parking brake pedal that you have to loosen up or remove to adjust the parking brakes. Why does it need to be replaced? I haven't looked yet, just read the manual. Is the nut a locknut or nylock nut? Secondly, the NFSM also states that the 12 bolts that hold the cover on the pumpkin cannot be reused. Is that also necessary, or can I run a die of the appropriate size to clean the threads on the bolts and a tap to clean the threads on the pumpkin and reuse the bolts with some threadlocker? Any responses will be appreciated. Thanks. :nerd:
