1 - 2 of 2 Posts
Just got the truck state inspected and it failed in some areas. Specifically, right side manifold, brake master cylinder, lower control arms (R&L), front wheel bearing & hub assembly, hood latch cable, and emergency brake.
I wanted to get your feedback on the parts i'm considering purchased, links below.
Brake master cyl: CARDONE SELECT 133139 {#440107S200, 460107S200} w/ Reservoir
Lower control arms: DORMAN 521181 {#545017S001, 54501ZR00A, WC121181} Complete Arm w/Ball Joint
Wheel bearing+hub assembly: TIMKEN SP500701 {#402027S000, 402027S100} Includes Sensor
Thoughts/concerns/suggestions?
Sounds like some cash to drop. If you do it yourself you could get better lower arms but they will work. The manifold, headers are your best option. If your going to keep it might as well upgrade the cost won't be that much different. Cajun seems to be the place to go. I'm not going to do headers until my warranty is up, but then.....
1 - 2 of 2 Posts
