They changed that in 06. The light comes on when a passenger is sitting in the seat.HudsonValleyTitan said:
They changed that in 06. The light comes on when a passenger is sitting in the seat.HudsonValleyTitan said:I noticed that the PASS AIRBAG OFF light under the radio illuminates when I first start the truck up but....isn't it supposed to stay on when the passenger seat is empty telling you the airbag for that side is off? Mine always comes on then goes off...passenger or no passenger. I don't think that's right.
Bullwinkle said:It is working correctly. Look it up in the manual.
The way I remember it is the light only stays on if there is an under weight passenger (kid) in the seat.
The air bag velocity is also tuned to the weight of the passenger, so you can tell your significant other that the passenger seat has a built in scale.![]()
Ok...explain that one to me. How does it not light up when the seat is empty if it's supposed to detect underweigh passengers? Can't get any lower than 0 right?Bullwinkle said:It is working correctly. Look it up in the manual.
The lights only activates "between" cretain weights. Zero is not one of them.HudsonValleyTitan said:Ok...explain that one to me. How does it not light up when the seat is empty if it's supposed to detect underweigh passengers? Can't get any lower than 0 right?
I'll have to read up I guess. All the ones I've seen only lit when the seat was empty....or a very light (like a child) was in the seat.:read:
04-05 are like you said, but they changed it in 06 to be off when nobody is occupying the passenger seat and on when there is. I typed that in the second posting....geeeez.GlendaleTitan said:in my 05 the light is on when noone is in the seat. Look at the pic of the guy on the light. It has a circle with an X on it simulating no air bag. So ...Light on = no air bag activation.Light off = air bag activated. Simple as that! So if yours is coming on then turning off when the seat is empty id say your seat sensor is malfunctioning. It should be lit when seat is empty or under sized person is sitting there.
