Arrgh. 2006 Armada. Nice last day of summer, drove with the windows down. When I went to put them up, the passenger front power window refused to move at all.
1. Tried both the driver's switch and the passenger switch. No luck.
2. Tried inserting the key into the driver's door and holding it on "lock" until the driver's window rolled up, but the passenger window still doesn't go up.
3. Weirdly, power door lock switch does not work either - on both sides. If I use the remote, the doors will lock and unlock just fine, but the switches on the doors do not work.
I'm thinking it's a bad switch? I popped the passenger door panel loose and took off the switch (window and lock) and reseated the connector, but no luck.
I searched the archives, and found some threads on this topic, but not sure if it applies to my 2006. Any ideas, suggestions, comments?
What is a Body Control Module (BCM), where is it located, and how would it be related to the windows, if any?
Thanks in advance!
--Dennis
Thanks in advance!
--Dennis
