I have a 2011 Pro4X, I need a passenger side headlight assembly. Mine still works but must have a bad seal as every time it rains or is muggy out, condensation forms inside and lasts for weeks...So annoying. I imagine a 2008 or newer light would work. Thanks
Can always pull it, dry out the condensation with a hair dryer, then just run some gasket maker around the seal on the outside. If it still gets condensation it's probably a seal around one of the bulbs. There's also a small piece of tape covering two holes on the back of the headlight that may be ripped or removed. I covered mine with electric tape then put some gasket maker over it.
Cheaper than a new light.
hmmmm...that's not a bad idea! Did you have a similar problem? I really like the stock headlight and want to keep it. I'll try that! Love TT! Thanks buddy!
Yeah when I modded my headlights I didn't put enough sealant between the two pieces. Instead of taking the thing apart, removing the old gasket, and putting new gasket in I just put a layer around the outside. It's not the prettiest, but I bought black gasket maker and you can't see it unless the headlight is out of the truck.
If it ends up being the area around the bulbs you can put a little Vaseline around that area and then replace the bulb. Just make sure to not touch any part of the bulb with Vaseline because they'll burn out really fast.
OK thanks I'll let you know how I make out!
