Passengers Seat Fluid Leak
1.1K views 4 replies 4 participants last post by  VQP0WER
While installing a 10" kicker sub under the passengers seat some fluid started dripping from something. Not sure which part it came from but now have an airbag light that is illuminated on the dash. Any ideas which part its from and how to fix it?
#3 ·
The airbag light is from the connector under the seat. Must have bumped it when working under there. You will need to unplug the Orange connector then plug it back in. Then do a reset on the light.
#5 ·
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
