The tow button as I understand just resets the shift points, and makes the tranny hold gears a little longer when towing. Unless your towing over 5000lbs I wouldn't even use tow mode.
It really only effects the first 3 gears, just holds off the upshift a little more.
I use it whenever I tow, and with bigger tires it helps to keep the trans from "shortshifting"
I won't hurt a thing by using it, but it is nice around town when towing, but on the freeway it doesn't seem to do much if anything...
Lou is right about holding the shiftpoints in the first three. There's no reason NOT to use if if you're towing. Exactly what are you going to be hauling? What's the weight? Are you on OR or BT gears?
well about 1,000 lbs in the bed and a 4,000 lbs trailer...my rear is a bit low with the 1k in the bed...I think i am going to install the PRG lift blocks i never put in when i ordered the mini lift....
That's exactly why I did the mini lift and not the level alone. I wanted a better stance when loaded. You should have any problems towing that. Go ahead and use the tow button. Don't be afraid to let her rev out a little. She's going to want to anyway.
just put in the rear blocks took about 30 mins....a lot better stance with 1k in the bed I have had the front spacers in for about 6 months....Now i won't be able to see what the whole mini lift really looks like till i unload ....now will this increase my payload, or just ride better?
Look inside the drivers door. I think it's around 5500lbs, but not sure. When I moved here to Albuquerque I towed a uhaul trailer (6000lbs) and about a 1000lbs in the bed, and it towed like a champ.
1 - 10 of 10 Posts
Nissan Titan Forum
Nissan Titan Talk Forum is a community for truck owners to discuss the Titan Cummins, Warrior, Midnight Edition and more!
