I dont think anyone has been crazier than me in this field. 2040# in the bed and cruised at 70 down the freeway smoother than silk! (*)
(*) Had airbags on it. (cheater)
Helinut1970 said:I dont think anyone has been crazier than me in this field. 2040# in the bed and cruised at 70 down the freeway smoother than silk! (*)
Exactly. I was doing that wayyyyy to much for my safety.cneary812 said:and thats why you drive a 2500HD now :teeth:
the titan will haul alot more than the stamped payload just not legally.
That's why I'm going to put airbags on my Titan. (But I don't think I'll ever put a full ton in the bed)Helinut1970 said:I dont think anyone has been crazier than me in this field. 2040# in the bed and cruised at 70 down the freeway smoother than silk! (*)
I have the firestone airbags and they are great. The only bad part is you can keep putting stuff back there and the truck doesn't sag, so you are never really sure how much weight is in there. I had a bed FULL of 4X4's, and 5/16 fence boards before the bags and the suspension was bottomed out, that is when I decided to get the airbags. Don't have a clue how much it weighed, but it was alot.Quartz said:That's why I'm going to put airbags on my Titan. (But I don't think I'll ever put a full ton in the bed)
helomech said:I have the firestone airbags and they are great. The only bad part is you can keep putting stuff back there and the truck doesn't sag, so you are never really sure how much weight is in there. I had a bed FULL of 4X4's, and 5/16 fence boards before the bags and the suspension was bottomed out, that is when I decided to get the airbags. Don't have a clue how much it weighed, but it was alot.
OK, I was a little crazier.... 2400 pounds (forty-eight 50 pound bags of sand). I just had one stretch of 65 mph road over the 20 or so miles home. I don't have air-bags (other than my soon to be ex-wife). It drove too nice... it was not alarming that you were in fact over loaded.Helinut1970 said:I dont think anyone has been crazier than me in this field. 2040# in the bed and cruised at 70 down the freeway smoother than silk! (*)
Basically yes, but the airbags are adustable. They can also handle more weight, I think combined weight of both bags is over 5000 lbs. Not that you should but that much in the bed. The biggest advantage to the bags is that even fully loaded you can level the truck so that you are not blinding everyone on the highway with you headlights.cneary812 said:dont the helper springs sortof do the same thing?
helomech said:Basically yes, but the airbags are adustable. They can also handle more weight, I think combined weight of both bags is over 5000 lbs. Not that you should but that much in the bed. The biggest advantage to the bags is that even fully loaded you can level the truck so that you are not blinding everyone on the highway with you headlights.
I have the onboard air compressor and I also have the manual ports inside my wheel well incase the onboard breaks. I bought the one that lets you air up each side independently.cneary812 said:yeah I have been looking into either airbags or helper springs for the near future but the airbags are more expensive and require an air compressor to adjust.
yeah I saw that one it is really nice but a bit pricy for me to justify at this time.helomech said:I have the onboard air compressor and I also have the manual ports inside my wheel well incase the onboard breaks. I bought the one that lets you air up each side independently.
I didnt buy the compressor at all with mine. I just used a 12 volt plug in compressor to are each one up individually.cneary812 said:yeah I have been looking into either airbags or helper springs for the near future but the airbags are more expensive and require an air compressor to adjust.
