1 - 20 of 203 Posts
Yes that is a Final Name.
PD for PreDrag. which is my first name.
and to fallow with size of the LS90mm Throttle body we have 90.
-------------------------PD90------------------------------------------
as we do with MGT90 for LS90mm and Venom 102 for LS 102mm.
As Jon Long from OWP has posted some info in his thread. I Would like to start my own thread and kind of get everyone to speed on the intake manifold.
Ever since I started hanging around on Facebook I have not been on here. For almost a year.
This Project Started last September. when I started looking into the Idea That JWT had when they started working on a same project.
trying to make M45 and FX45 variable intake manifold fit and work for Our VK56 Platforms.
For some Reason. they stopped and left the Manifold to sit and collect dust on their shelf.
At the same time around September last year. I was Able to Find and Purchase a Used Intake Manifold. And that's how it all Started.
Little less then A Year. I did all the R&D and put it all together. and right now we have a fully operational Prototype on my Pathfinder
I will be adding more Information its getting late. here Are few Pictures of it installed on My Pathfinder. It runs Like A stock. no issue with Cold starts. she fires right up. and we are in Test And Tune stages. no issues with heat being that its Aluminum intake.
I just made a 200mile each way trip to Carlisle PA Meet last weekend without any issues at all. Very good results so far. She pulls hard. Besides myself there are 2 more testers.
1 is 05 non VVT Titan. And another is 07 VVT Titan.
We all Have Dyno And 1/4 Mile track results from Stock Intake Manifold Setup, so it can be compared to the PD90.
Discussion Starter #2 (Edited)
""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""We are going to have a special on first 5 Plug and Play Intake Manifold Kits. they will include new LS90mm Throttle bodies for free. Everything you will need to get it to work will be included in this Kit. You will use your Injectors. The Price will Be $1,500 Dollars. After we sell those 5, Price will go up.
It will be sold Threw Jon. Open Wide Performance. And it will be Tuned by Randy Baker. As with other Intake Manifolds You will need an Uprev TO be able to Tune for it. Randy Baker has been in this Project from The beginning. If he told me he wouldn't be able to tune for here. I would have not bothered doing the project.
We will also Have an PD102 Option around $500 dollars Which will be Fully Ported lower Intake Manifold. and it will come with 102mm to 92mm Throttle Body Flange. You can use it with 102mm Or with 90mm Throttle body. and It will Improve the Air Flow. 1 of our testers Dereck Johnson will have this ported manifold on his vvt Titan. and we will also have his results later on with CS2 cams. that he has already waiting to get test results on stock cams.
Before you guys start questioning the prices. This can not be compared to MGT90 or VENOM 102.
if you go to Nissan and purchase this upper and lower manifold new, You are looking in spending close to $1,000 dollars just for the manifold alone.
At $1,500 dollars I am loosing $. but I have invested so much into this that I need to start getting some of it back.
- Intake Manifold, Adapter Plates, Throttle Body Flange Fabrication To Clear our Thermostat Housing, and LS90mm Throttle body a alone is at $1,500 dollar range. not counting Fuel Rail and modification, all the hardware , all the parts and work to get it put together. this kit need over 30 different parts to make it all work.
SO How is this Manifold Different then the Other Manifolds?
For 1 this manifold is not a modification of a stock manifold.
When I say stock I mean all 3 ( STOCK, MGT90 AND VENOM 102 ) manifolds.
Besides all 3 of them having Different Diameter Necks, and Different Diameter Throttle Bodies,
They all use same Stock Long Runner Intake Manifold.
Best Way to explain PD90 is. If you where to put Stock Long Runner manifold and PerformanceVH short runner manifold together into 1 Intake manifold. You would get PD90.
Stock long runner manifold, no mater if its mgt90 and or venom 102 is designed to give best torque. and it starts loosing Horsepower. in upper rpm range.
PerformanceVH Short runner Intake Manifold. losses the low end torque.but builds a lot of HP vs stock up in higher rpms. even more with aftermarket cams.
PD90 has 16 runners.
it has 8 - 17 inch Long runners, which are same length as the Stock intake manifold long runner. Plus we have 1 inch adapter plates that make them 18 inch long.
and it also has 8 - short runners that are attached to the short runners. and each 1 has a butterfly valve that opens and closes when needed.
so with PD90 you have it all. Long runners for low end Torque. And Short Runners for Top End Horsepower.
Here is how the DUAL STAGE VARIABLE Intake Manifold works, Explained by NISSAN.
Here is MGT90 next to PD90 from front and back. you can see how it looks VS the Stock manifold. the PD90 is shorter by 1 inch. in height. but The adapter plates are 1 inch thick. so they are same size in height, when installed. made to fit. Titans, Armadas, QX56, Pathfinders, and vk56 swapped Frontiers and Xterras.
the opening on PD90 is 92mm up down x 87mm side to side.
it gets ported to 92mm opening.
Lower intake manifold and half od the 16 runners. with 8 long runner Bell Air Horns.
Inside of the upper Manifold. you can see the long runners and the Bell air Horns and Brass Butterflies inside the Short runners.
Closed and Open position.
COMPLETED:
MY LITTLE COLLECTION:
Discussion Starter #3 (Edited)
I am Going to post Mine and my testers Dyno and Track numbers for comparison of Stock Intake Manifold VS PD90 Intake Manifold.
Here Is my Base Numbers from OEM Stock Intake Manifold & Throttle Body. 2008 VK56 VVT Pathfinder.
DYNO:
My best numbers where 319HP/369TQ. but the first place I went they did not know how to keep it from shifting gears, so Dyno charts looked like a mess.
2nd place I went they knew what they where doing. so I am using this Graph as my base numbers.
313HP/360.10TQ:
1/4 Mile Track:
Here is my 1/4 mile time with Stock Intake Manifold.
13.802, my Vehicle number at the track was 1840.
Tester #1, Mark Buitureira from Maryland. Owns 2005 Non VVT Titan:
Tester #2, Dereck Johnson From Louisiana. Owns 2007 VVT Titan.
His Base Stock Manifold Dyno Numbers Randy Baker Tuned Are: 305.05HP/343.91TQ. File # 003 In Red Color.
And His Base Stock Intake Manifold Setup 1/4 Mile Track Time of 14.178- RWD with TT
Discussion Starter #4
Save for more Pictures And Information
Damn it looks good in there, I like the black.
In for more information
Reactions: forgottenzone
woooow that's look so clean and fresh. looks like this community statin to wake up again.
sub. for more pics, details, numbers and gains for this fresh IM.
actually am starting struggle between all of the latest IM's which one to buy.
great job sir waiting for more details soon enough and good luck on that...
Discussion Starter #7
Updated 2nd Post with more Information, and more Pictures.
This is so tempting! I plan on replacing the starter next month and since I'm going to remove the OE intake manifold to access the starter, is this PD90 setup pretty much plug and play/bolt on?
Just need to be tuned by Randy Baker.
Dyno results? Track results?
Discussion Starter #13
PrimoV8 Yes sr. I am including in the kit as plug and play.
You will use your Injectors, and you will need to have Uprev Tuner, and have Randy Baker Tune I for you.
it does start up, Idle and drive like stock on stock uprev tune for your OEM Intake Manifold. I as running it with ong runners and getting tuning logs. ad was also testing it with stock tune in Variable long runner and short rur mode without any issues. but there are quite a few thing that will need to be adjusted by Randy to make it perfect.
Primo... Boriqua? I live 10 Minutes from NYC. PTown, NJ.
Discussion Starter #14
ostaF, As you can see my posts in Facebook. and if you Read my 2 posts in here You would know that it was Just installed, and its in Testing and Tuning Stage. Also I don't think I will be Doing Dyno and Track in 100*+ temps. But I am happy to post Mine, and My Testers Base Stock Intake Manifold Dyno and Track Numbers in the post #3.
Which we will be using for Comparison.
Discussion Starter #15
Added More information in the Post #3.
Dynos use SAE and STD correction factors, 100* weather doesn't matter.
You want the weather conditions to be similar at the track. We don't want to see you do what Walt did, make the second run in much colder weather and claim huge gains on the product alone.
I figured you'd want to hit the dyno and track ASAP no matter the weather, come on man, we want to see you beat some domestics
Reactions: 2009blackbeast
DYNO:
313HP/360.10TQ:
1/4 Mile Track:
man great numbers you have there. awaiting for results soon enough hopefully..
good luck Sir..
Discussion Starter #18 (Edited)
No, I do not want Conditions to be same at the track.
I did not do this Project to Prove anything to anyone.
I made this Happen, So I can Make my Pathfinder Better and Faster then it Is.
I Did not ask anyone for any Financial help with this project I did it on my own.
SO Please don't use anyone else Like Walter, Jon, Cory, Mike, to compare. they all do their own thing. they all Mod their Vehicles the way they want, Just like you do, And I do.
And I am not here to compare what I did to anyone else's work. the only reason I am doing all this Data, Is because People Like Yourself want to see the difference.
I also stated that intake manifold is in Tuning stage, and once its all done I will go and do Dyno and Track. I need to make sure, Everything is working the way it should, before I send Intake manifolds to my testers. I am testing it on my own vehicle to make sure no one will have any issues.
Again this is not Single stage, But Dual Stage manifold. a lot more stuff involved. and other people working with me to make it all work. not just myself.
Believe me you will see the difference no matter the weather.
Selling them I am Trying to Get my investment back. and I will not be selling anything by trying to give false numbers. this is why I chose Neutral Testers as well.
I can easily take all I invested And throw it in the Garbage, and Call it a day.
It doesn't take much for me to do so.
And never look Back.
Why not run similar conditions to your slip in June? Having all other variables (weather, weight, tires, DA, etc) controlled helps isolate the true gains of the VK45 intake manifold.
Anyways, good luck with it. I'll check out the results like the other members here.
I want this manifold to work, and I want it to destroy the MGT90 in a dyno and track comparison. For real! I honestly think this should be the dominating manifold option out of what is currently available.. The science and operation behind this manifold should work very well especially in the upper rpm range (past 4500rpm range) due to the closed runners. Simple fluid dynamics and physics. It should also respond very well to cammed titans.
JWT started this project what seems to be nearly 10yrs ago but never finished it, so i'm glad to finally see it come to fruition. I enjoy every aspect of this build especially because its something everyone has wanted to see for many years.
Crazy how far the titan platform has come just within the last 3yrs with modifications.
1 - 20 of 203 Posts
