Does anyone know how to or if it is possible to customize settings. For instance, I know it is possible to turn off the horn during setting of the alarm using the key fob, I know you can turn off the speed sensitive volume control through the radio but the owners manual sugguests that you are able to turn off the speed sensitive mode for the windshield wipers.
Another function I would like to change is the auto down function of the power windows as activated from the key fob.
I found this on another site and was wondering if this is applicable to the Titan.
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: 3 seconds
Mode 3: 5 seconds
I still can't believe Nissans do not have an "auto door lock at 20mph" feature. What were they thinking?!
[edit] Duh! What was I thinking? To change between Hazard and Horn Reminder Modes 1 and 2, simply hold down the "lock" & "unlock" buttons on the keyfob simultaneously for a few seconds.
If so, how do you access?
Dome Lamp Timer
Mode 1: 45 seconds
Mode 3: 2 minutes
Mode 1: 45 seconds
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Mode 1: 3 seconds
Mode 3: 5 seconds
