For us californians, we can't touch the cats... Or that's what I assume ....
looks good
looks good
You could do what he mentioned and punch the guts out. That way they would only be able to tell if they dismantled your exhaust and looked inside.phillipyang said:For us californians, we can't touch the cats... Or that's what I assume ....
looks good
True. Those OE cats are heavy.HavockWK said:At least your new resos should be a little lighter than those boat anchor cats! Kind of surprised that just doing these small pipes cost about half as much as the rest of your system though.
Don't forget to update your audio clips!
HavockWK said:You could do what he mentioned and punch the guts out. That way they would only be able to tell if they dismantled your exhaust and looked inside.
I guess if they use a "sniffer" type test. If they just use the plug in type that they use here, it will pass.BigBlackTruck said:Until he goes to pass an emissions test, and FAILS.
The two rusty "missile looking" sections are the OE catalytic converters. What makes me absolutely positive of this, is the presence of the "honeycomb" shaped catalysts that occupies the widest internal part of tube. They are only about 2 inches thick, looks flimsy without real function that their removal (IMHO-and I could be dead wrong) has little or no significant effect to the total exhaust pollutants (4x2s have only the front cats).Yomama said:Those look more like resonators then CATS to me.
First, IF you choose to 'punch out' a catalytic converter, DON'T BREATH THE DUST. It contains heavy metals ( Platinum and Paladium in the oxidationgr8titan said:The two rusty "missle looking" sections are the OE catalytic converters. What makes me absolutely positive of this, is the presence of the "honeycomb" shaped catalysts that occupies the widest internal part of tube. They are only about 2 inches thick, looks flimsy without real function that their removal (IMHO-and I could be dead wrong) has little or no significant effect to the total exhaust pollutants (4x2s have only the front cats).
There are tons of threads why 4x4s have 2 pairs while 4x2s have one pair of cats and had been discussed and killed a thousand times BUT no clear-cut reason seems to surface. Anyway, in NJ, new cars have 4 years of no emission testing and I hope and pray that when the time (3 more years) comes to have my Titan inspected, the NJ-DMV does not know the difference between the 4x4 & 4x2 exhausts.
I may just try to punch one section out and document with photos just to see how it works.
I "punched out" out one of these honeycomb catalyst late today. I secured it on a table vise and using the straight end of a crow bar, punched a hole thru. That sucker crumbled like a dry cookie!!! Total time of removal of catalyst: 5 seconds. It took longer for the dust to settle :clap: :clap:carteach0 said:First, IF you choose to 'punch out' a catalytic converter, DON'T BREATH THE DUST. That flimsy section is a ceramic honeycomb and is quite strong unless abused. Most last the life of the vehicle without a problem.
gr8titan said:I "punched out" out one of these honeycomb catalyst late today. I secured it on a table vise and using the straight end of a crow bar, punched a hole thru. That sucker crumbled like a dry cookie!!! Total time of removal of catalyst: 5 seconds. It took longer for the dust to settle :clap: :clap:
I'm sorry, I just can't get over the humor in using something rusty as a point of reference in photos (since I did the same thing....) :smokingcogr8titan said:The two rusty "missle looking" sections ....
What did you do? Make the "rusty" as a point of reference (LOL) or punch out the honeycomb catalysts? If it was the later, any change in your truck's performance?steves said:I'm sorry, I just can't get over the humor in using something rusty as a point of reference in photos (since I did the same thing....) :smokingco
No, Sorry....in the pics I posted of how the hitch fits around the exhaust I had said "that rusty piece there..." and the OP used rusty to describe something in his photo.gr8titan said:What did you do? Make the "rusty" as a point of reference (LOL) or punch out the honeycomb catalysts? If it was the later, any change in your truck's performance?
