1 - 8 of 8 Posts
I know, I'm going to be that guy...but I have an excuse! My laptop runs pretty slow so surfing the web can be challenging and my work computer blocks a lot of images on the site. I was hoping to get a condensed thread for my wheel and tire idea. I'm looking for guys that are leveled up to 3" in the front, no bracket lifts. I have bushwacker pocket styles and I am looking to get my wheels this summer. I can't stand having my tires tucked so far in the well. Could anyone with fender flares post up some pics with 18's that have 0 to -12mm offset and your tire sizes? I'd really appreciate it!
Discussion Starter · #2 ·
Anyone? Searched some and found threads but most images are blocked here at work.
I don't have bushwacker flares, but I have 275 tires on 18x9 +12mm offset. They stick out about .5 inches from the Pro4 flares. 0 would be another half inch, -12 would be 1.5" outside the wheel well.
I am not sure what my wheel offset is. I have leveling spacer and Bilstein 5100 on the middle perch. About 2.5" lift in front and a 1" rear block. I have the bushwacker extend a fender Land vehicle Tire Vehicle Car Motor vehicle
Yeah I talked to Osiris and have been playing with some calculators online. I'm between keeping my stock size tires and going with -12's or getting 295/70's with a 0 offset wheel. From a financial standpoint, if the 275's with -12 look ok, I will go with that.
Here's the best picture I have of stock size with -12. I had 1" spacers on my +12's.
I am not sure what my wheel offset is. I have leveling spacer and Bilstein 5100 on the middle perch. About 2.5" lift in front and a 1" rear block. I have the bushwacker extend a fender View attachment 427010
If you could find your offset and have any pics from straight on, I'd appreciate it!
Thanks man, it's hard to gauge without the pocket styles but they stick out further than the pro-4x flares by about 2". I think -12 with stock tires may be enough but I don't want to not like it and then have too much offset for a larger tire to fill the wheel well.
An option is bora spacers. You can get them as small as 1" (~25mm). I went conservative with my wheel offset with the idea of using them if I wanted a wider stance.
Reactions: MotoMark
1 - 8 of 8 Posts
