mine peeled right off around the letters but it wouldnt hurt to have a razor blade handy just incase. make sure its good and dry before you go to peel it off. it makes it way easier and it should come off in a couple of big chunksIts extremely dry here thanks for the tip though. Oh quick question when I go to Peel it off do I need to cut around the letters or will it not Peel off the chrome.
How often if you have to redo them?mine peeled right off around the letters but it wouldnt hurt to have a razor blade handy just incase. make sure its good and dry before you go to peel it off. it makes it way easier and it should come off in a couple of big chunks
its been on for about a month for me and it hasnt chipped cracked faded or peeled off at all. its been sitting in the lovely south GA heat, rain, its been covered in ash because of wild fires we have down here and been washed and scrubbed a few times and its still holding strong. as long as you prep the surface of what you are spraying and its dry then you shouldnt have any troubleHow often if you have to redo them?
I'm curious if plastidip peels off so easy or wipes of on the paint how well does it last on the badges? Thanks.
i havent done my handles yet, but you could just mask it off for pop off the trim piece around it spray it and pop it back onwhat about the key holes?
