Please Help A kid out I Need Preformance Mods
826 Views 6 Replies 6 Participants Last post by  sandpond
Im re doing my 2005 titan and just got 6 inch lift on it and i need some preformance mods. I have little time to research becuase i play college ball. i need some pretty good start out mods for a resonable budget i would be greatly apreciated and if u help me out even further i hook u up with some pac 10 stuff so please help me out
Performance mods? Hmmmmm.. You should start with the 2° timing advance. It's either free or relatively inexpensive. Many Titan owners who own Cipher or Osiris do it for other members or you can ask your dealer to do it for you. Here's a thread where members who can do it list where they are located:
http://www.titantalk.com/forums/tit...ky-who-can-give-2-degree-timing-advances.html
Here are the instructions for a dealer to do it:
Warm up vehicle.
On CONSULT 2 screen choose ENGINE
After communication with Convertor will display a bunch of choices.
Press WORK SUPPORT
See more choices, press TARGET IGN TIMING
Press UP x2 for 2 degrees, correction which you should be able to see.
Press UPDATE.
Now press BACK
On the menu screen find IDLE AIR VOL LEARN.
Press, and perform to correct your idle since you just raised it 75rpm with timing advance.
Next would probably be the CAI. There are dozens starting in the $60 range up to $400. Many to choose from. Check out this thread:
http://www.titantalk.com/forums/tit...tions/30324-air-intake-systems-list-poll.html
Injen is a really nice one. Many like the Volant since it's a closed top system. Others like AEM Brute Force or Nismo. Note that the oiled ones can cause issues with your MAF sensor if overoiled.
Third would be an exhaust. Again, dozens to choose from:
http://www.titantalk.com/forums/tit...s/29965-exhaust-systems-sound-clips-list.html
Banks is very popular on this truck but the JBA Evol gives the best performance of the various units. Volant also has an eshaust as does Nismo, Flowmaster, Magnaflow, etc. It all depends on your wallet and the sound you want.
Some put TB (throttle body) spacers on to try to get better airflow into the engine. Some say they work, others, :dunno:
Another relatively cheap perf mod is the throttle body bypass. The TB bypass eliminates coolant from flowing through the TB. Warming TB temps in winter improves performance. Eliminate hot coolant through the TB in the summer should = more HP. It's not much, but it helps.
More advanced, and expensive performance mods would be the Stillen VK-Pro which is a piggyback performance chip that you install. It's around $700. Or you could get UpRev to tune your truck by sending them your ECU and they will remap the settigns for better performance per your specifications. Or you could buy their Osiris package which gives you the ability to not only get it tuned by them but update your tune as you add mods. That will set you back $700 too. A Stillen supercharger costs around $7000 and a Vortech is around $5000.
Here's another thread to read that summarizes many of the various mods and typical questions about this truck.
http://www.titantalk.com/forums/titan-general-discussion/47863-best-titantalk.html
Hope this helps. Also, what's your budget? That might narrow down the mods a bit.
What college do you play for? "misslelau and what sport do you play?:computern
If your looking to save money go with the 2* timing advance first. Then you can order a Magnaflow muffler from http://www.performancepeddler.com/. You will need part # 12256 which is a direct repalcement for the stock muffler. I bought mine for $63.00 delivered to my door then paid a muffler shop $45.00 to weld it on. After that a cold air intake (CAI) will set you back a few hundred. You can get a Nismo, AEM, Volant, or S&B for under $300 if you search around enough. Good luck.
pack 10 school football
I thought it was PAC 10, what school did you say? And what kind of stuff are you looking to give in return? Yes this should be interesting.
