OK 2008 Titan LE auto light as all LE's have...
Ordered a set of 55w 6000k Hids from Xtreme Hids out of Greensboro NC for 90.00 came with a 2year warranty.
Installed them without incident to spec, they are a plug and play set up no relay, just plugged straight into my stock wiring harness.
Problem is, they have a faint flicker, twinkle whatever you want to call it, they arnt flickering on and off, they just do not have a Solid Pronounced Beam. Worries the piss outa me
I noticed when i first turned them on and called the company, they said it was normal to wait a day or so and it would clear up. Its been a day or so and still doing it. Ive tried just turning the lights on with engine off, then engine on, idling, or driving!!! Its all the same. They both flicker randomly. I have checked all connections 14 times all good and solid, also checked all fuses. I dont understand it. I have researched all I can take, and every solution I find someone proves the previous person wrong.
Only thing I can figure is that it is the Ballast, or the bulb or both. I just dont know.
PLEASE someone tell me what to do before i rip it all out and go back stock.
I read all the reviews on this company and have found nothing but good things to say about the products.
Do I need a wiring harness and relay??? Ive read that it will help protect my truck wiring sys but I havnt found solid evidence that this is the problem....
PLEASE HELP ASAP!!!!! THANKS
