Yesterday, my truck refused to start. Cranks well but just won't start. I noticed two strange things. The AC or condenser fan comes up even when the ignition is in the "ON" position and the fan regulator is OFF. Secondly, the security indicator light on d dash comes on and remains solid after 3seconds of turning the key to the ON position. I have tried everything I read .....from swapping relays in d IPDM to resetting the security by locking the car with the key in two rapid succession. Can't say I have checked all the fuses bcoz I really don't which to check(although I checked a couple) Any ideas? Pls help
Bad chip in the key? Try a different key?
Thanks but it's not d Key. My driver connected two 12 volts batteries in series because he said the battery was weak. I have a feeling that the ECM is the culprit but I wanna here from the gurus in the house
In series? That would be 24 volts. Not good.
