Installed PML pan and torque to specs given. I did have a very slow leak at the drain plug where Matic-S was starting to seep out. I think 20 ft lbs is a little low for the drain, bumped it to 30 and no leaks yet. Anybody had an issue with these pans leaking...at the drain?
I used supplied drain plug with copper washer
