Popping/ Creeking sound coming from front end
1910 14
I have an 04 Titan LE with a CST 4" spindle lift, Radflo front coilovers, bilstien rear shocks, fabtech 4" rear blocks and u bolts. Anyway every time i make a slow hard right or left turn like backing out of a parking space i get a popping/ creeking sound coming from the front end. When i got it aligned a couple weeks ago the guy told me its the tie rod end bracket or something like that. I took it to the dealer yesterday and they said there was nothing wrong with it ????????. Doesn't seem like that could be right.They said they checked the rack and pinion set and theres nothing wrong no play in it. Popping usually means somethings wrong. Any help would be greatly appreciated.
Thank you,
Dave
1 - 15 of 15 Posts
I have 2 noises with mine (CST spindles & Radflo 2.0's)
1st noise when going left too right or vs. is Spindle hitting lower control arm ( normal - steering stops )
2nd noise I have from Radflo's front end over bumps..
Does it make a pop sound when you turn left or right hard?
Yes i does.. When your pulling in or out of a parking spot..
Damn i wonder what it could be? It's got me dumb founded
I shaved down where my spindle hits my lower control arm - went away & then came right back..so i'll just live with it..
i might have to too its just really embarrassing and doesn't sound right
If you bought it from PRG you could just call Greg & ask..
Tried calling greg..... Just went out and looked at the bottom a-arm and theres a dent in it from where the spindle is hitting it. Thanks for the info.
No Problem..
You should have joined us last weekend at Mission Bay..
You could have seen Greg & another titan with his new Mid-travel Kit..
Discussion Starter · #11 ·
was it a sick set up? i haven't been on here in a long time. whens the next meet you know?
Discussion Starter · #13 ·
Cool thanks alot. I'll be moving up north by fresno next week so hopefully theres some up there.
1 - 15 of 15 Posts
