Hey guys, need some help isolating a popping noise coming from the driver front side of my truck. I have a 2013 PRO4X. I notice it going at a crawl going straight in parking lots, talking about 5mph, seems to get a little worse when I hit the brakes. It also seems like I have to drive the truck for a little while before it will start popping. Suspension articulation does not change the noise, it still remains on flat ground. I have replaced my lower control arms with OEM ones with adjustable bolts, also replaced sway bar bushings, struts with Bilstein 5100's, outer tie rod ends with OEM ones, and wheel bearings. I would not think this is a CV axle issue since I do not have to be turning for it to occur, I have physically tried to move the CV axle by hand, but it is tight, no play. Front drive shaft seems OK as well. It does it in 2wd as well as 4wd, so would not expect a front diff issue. Any advice on what to check next? Thanks.
