so a while ago about 2k miles ago, I installed JBA LT's what a PITA that is.... but super happy with results
after install I thought I heard a leak
one of the studs stripped out on me and I had to drill tap and heli coil....(hence the PITA install)
and I thought that was the problem either that or the B pipe connection
ive since then re torqued the header nuts
so since I was done with dealing with exhaust myself i brought it to a shop, they checked it over and over, called a few guys and could not find a leak.
I will bring it to another shop to get different guys to take a look at it
but I swear to god, I hear a slight " pap pap pap pap" at idle and while cruising around
the guys at the shop said that with headers that you hear the injector pulse a lot more, and it sounds like a leak/lifter noise sometimes
I still have stock exhaust only thing I have is JBA LT and UpRev
has anyone else had this problem? what should I be checking?
