who's done a level kit w/ 35s?!?!
Many people have!!! Might have to perform the Pinch Weld Mod but it's done consistantly...........albonismo said:who's done a level kit w/ 35s?!?!
So your saying it can't be done with an aftermarket wheel with less BS, say 17X8 w/4.5 and Zero OS???NorCal 4x4 said:Needs to be the stock wheels, or at least the same backspacing and width.
I wouldn't say can't, but it would require a lot more cutting, and you still might rub at full steering lock.yscty said:So your saying it can't be done with an aftermarket wheel with less BS, say 4.5???
The reason I'm asking is that I have the AR MOJAVE TEFLONS and was gonna go to a black powder coated stock OR wheel but am not now and am still gonna run the 315/70/17 I think, or it might be the 305....Having trouble finding someone with the same set up to see the outcome tho. I have no problem with PWM if need be............NorCal 4x4 said:I wouldn't say can't, but it would require a lot more cutting, and you still might rub at full steering lock.
My friend has 35s, on his Procomp stage1 lift, and Moto Metal 951s. 9" wide, and 4.5" backspacing. Even with the big lift, he had to do the pinch-weld-mod.
Some guy on here had the same exact wheels, as my friend's, but just a level kit, and he had to do the pinch-weld-mod with Nitto TGs in the 295/70/17, and that's only a 33.2" diameter tire in that model.
And going with an 8" with 4.5" b.s. would be better than a 9", but it still is sticking out an extra inch, and sticking out is what causes the rub.
Well two things in your favor. First the 17" BFG ATs are only 34.5" if you have the 315/70/17s, and second they are not as wide as the 315 sounds, only 11.8" wide on an 8" and 11.6" on the 7.5s.yscty said:The reason I'm asking is that I have the AR MOJAVE TEFLONS and was gonna go to a black powder coated stock OR wheel but am not now and am still gonna run the 315/70/17 I think, or it might be the 305....Having trouble finding someone with the same set up to see the outcome tho. I have no problem with PWM if need be............
BTW - yes I do have the 2" leveling kit.......
It's a 7.5" width nominal, but should measure about 8.5" wide ... outside lip to the outside of the other lip. [yscty has, or was getting some 8" wide aftermarket rims].AF CO Josh said:I'm guessing the stock OR rim is 8" then?
I just picked up a set of OR rims for my truck with TPMS for $160 from a local guy. Now I need to find my tires. Christmas for ME!
Chance of snow showers late this afternoon and snow tomorrow!!! So those pics shouldn't be a problem........ :cheers:AF CO Josh said:Norcal, thanks you rock! I'll have to get off my butt and get some pics of my truck on here this weekend. Hopefully covered in Colorado snow!
