1 - 2 of 2 Posts
I'm Hooking A Amp Under The Passanger Side Front Seat And Need To Know A Good Place To Run The Power Cable To The Battery. Also, Where Do I Drill The Holes To Mount The Amp Under The Seat Without Putting Holes In The Bottom Of The Truck. Help Please.
There have been a ton of posts on this... if you look around you should see lots of options. There are a few openings in the firewall you can work with.
1 - 2 of 2 Posts
