Do you mean power folding mirrors or power adjusting mirrors?
Power adjustingDo you mean power folding mirrors or power adjusting mirrors?
It will be prewired make sure you get mirrors with the 6 pin connector and not the 16 pin connector. The 16 pin is for the LE trim.
The only options available on the 6 pin connected mirrors are power tilt and Heat. If you are looking at a mirror that has any other option on it such as Puddle light, signal, auto dim or power fold (only available on the non tow mirror) it will definitely have the 16 pin connector.
All mirrors from 2004 - 2015, big tow or regular use the same pin out on the connectors and also will physically be compatible with your truck. The only thing you gotta look out for is whether or not it has a 6 pin connector or a 16 pin.
