If you have the memory driver seat, I think your keyfob has been linked to a memory setting but it is not the setting you use. The instructions on how to set it are in the manual - basically you push the memory 1 or 2 button on the door panel and then push the remote button. When you unlock the car and the remote has been linked to the memory, the driver seat will return to the memorized position. You can link the different remotes to different memory settings.
