I had changed the power steering fluid on my truck to royal purple using the emptying the reservoir with a syringe and filling every week till i swapped the the full capacity the system holds. I would spill a little and would clean up what I would see every time I did it. But when I did my oil change I noticed that the hose that's directly under the reservoir has oil residue on it so I thought maybe I forgot to clean it, I wiped it clean and checked again today and it has residue again. It seems like it's coming out through the top of the hose as there is a little tiny build of oil around the top of the hose. But not sure how that's possible if the end is facing up and the clamp is on there. Could it be the bottom of the reservoir?
