1 - 10 of 10 Posts
Guys, my power steering resevoir has been leaking lately and it seems like it is leaking from the top? Any ideas? I checked the green O ring and it seems fine, but maybe I will replace it just to be sure.
is the cap tightened down? i would assume you checked it for being over filled while hot and cold right? if so, take the cap off, look at were the threads are on the bottle as well as the cap and look for any cracks. could be hard to see. if thats good, like you said, replace the O ring. if that doesnt work, get a new cap as well...or just buy both the first time. if none of those work and its not over filled...you got me.
how much is leaking out?
It leaked out enough to make it drop below the "min" level marker.
ya thats quite a bit...
the cap is completely on when you hear it click btw.
take the truck out, warm up the power steering fluid a bit, then pop the hood and have someone cycle the steering to see if you can see the leak in progress. moving the wheels while the truck is still requires the most pressure. also make sure the feed and return lines are tight. those little clamps can get weaker over time.
also, whenever you find the leak, i would completely flush and re-service the system to be safe. small contaminants can really irritate the system. good luck. maybe others will have better ideas or experience.
Thanks a lot man!! Thats really good info :)
Wow, this is odd. The cap in my '91 Ranger does the same thing and I've been posting over at the Ranger forum for answers. The O-ring is one suggested solution as is adding a vent tube to the cap to give the pump/reservoir some expansion capability.
Why does this happen? One theory on the Ranger forum was that it happened when you turned the steering wheel without the engine running. I tried that on my Ranger and the theory didn't hold up.
Discussion Starter #7
How often do people turn the steering wheel without the engine running? LoL
Hyper-miling. The first few blocks from my house are all downhill.
Discussion Starter #9
What's hyper-miling? LOL
1 - 10 of 10 Posts
