1 - 1 of 1 Posts
I am new to titan talk but have question. I recently replaced valve cover gaskets on my 06 nissan titan 2wd. I was leaking pretty bad so after fix drove to work and now windows will go down with all switches but none of the switches will roll up the windows also when i lock truck you can now barley hear my horn. Door locks work fine. Any suggestions on what it could be? There is a wire connection that is located on the driver side valve cover right where the leak was but not sure what it goes to?(in the back toward dash bottom corner)
1 - 1 of 1 Posts
