1 - 3 of 3 Posts
Can someone please tell me how you ran the power wire from the battery to your amp? I can’t see where there is a spot to go through the firewall on the passenger side. Pics, advice would be helpful. I’m no expert but this isn’t my first rodeo either. I’d hate to have to run it through the driver side but I’d that’s my only option then I guess thats what I’ll do. Fully intended on doing this today and it looks like I’m having to stop before I even really got rolling. Not a happy camper right now.
I had the same issue when I was trying to run a 4gauge wire for my amp. I ended up just coming up from the bottom of the cab under the passenger side seat. It was where I wanted to put the amp anyway and it worked perfect. There was a factory ground there to use as well. I used a Stinger waterproof grommet to protect the wire and keep everything waterproof.
541593
541592
Reactions: FlawleZ
titanse05, Sorry for the misunderstanding but is there a hole there already or did you actually drill one? Hard to tell from the pictures.
1 - 3 of 3 Posts
