21 - 40 of 47 Posts
I have a 2017 P4X with 14tk miles. If this kit is adjustable 0-3" what size tire can i fit on my 2017 p4x? whats advantage to getting this suspension system? Thanks for the response,
Discussion Starter · #26 ·
Hey, the kit is height adjustable from 0-3" of lift. I recommend a 305/65 or a 295/70 tire. Some have fit 35" tires with just 3" of lift but that would require cutting.
This kit has alot of advantages. The number one most unique thing about this kit is that although it is Icon brand it is an OEM Nissan part number so will not void warranty. Many have said this rides way better than stock and these trucks should have came from the factory this way. Although you won't have to for a very long time the coilovers and rear shocks are fully rebuildable which means they will outlast your truck.
The upper control arms that come with this kit are unique because they have Delta joints. The Delta Joint was designed for the climates that the uniballs have not been able to stand up in. I.E snow, road salts, high moisture, etc. The Delta Joint in simple terms is a "sealed uniball" that is greased instead of using a teflon liner. ICON is estimating these to have life spans of at least 100K. The benefit of the Delta Joint is that you don't get the noises that are accompanied with a dried out or worn out uniball.
When comparing the uniball straight across to a Delta Joint, the Delta joint does have quite a few advantages.
1. No noise with the Delta Joints
2. The Delta Joint has a stronger pull out strength compared to the uniball.
3. The Delta Joint is a one piece design, so no more misalignment spacers or broken spindle adapter spacers.
4. Comes with a 5 year/100k warranty when used with Icon suspension kits
5. Delta Joint gives you the same high misalignment angles of a uniball.
How's that for a thorough answer? Lol
Any chance you have any pictures with the below tires sizes on a 20/21 pro4x?
Discussion Starter · #38 ·
Does this system fit 2012 Pro 4X crew cab?
Yes. No problem what so ever. Suspension is the same for all 2004-2021 Nissan Titan non XD.
21 - 40 of 47 Posts
