I know, probably been beat to death but cannot find info I need through search function.
I just mounted Nitto Terra Grapplers in a LT285/65-18 on my stock wheels after installing Bilstein 5100's using the 1.5" lift setting. Everything is aligned properly. No rubbing etc.
My question is about tire pressure. The guy I had install my tires said I need to run between 60 and 70 PSI due to the tires being an LT version. Is this true? The sidewall states 80PSI max.
Currently got pressures set to 55PSI all around and the tire pressure sensor is lit on the dash. Tires feel a little wallowy up front at this pressure.
Is there a way to reset the value in the computer to the higher pressures or should I look keep dropping pressure until warning light goes out?
John
John
